BmoreBateman
Nov 08, 2019Guide
XR500 Wifi Slows to a crawl
Hey everyone, I have been banging my head against the wall the last few days. I have been having a issue with my XR500 that I have had for awhile now. I cannot seem to keep my wifi speeds stab...
- Nov 18, 2019
Great News! I rolled back the firmware, replaced the power cord because it randomly went into a boot loop on .32, Moved the router in a Upstairs closet on the other side of the floor... everything has held stable. I even updated the firmware to the current version Friday night. Everything has held strong in that time. I'm saying I was either getting really bad interference where it was at or the power cable was failing and wasn't providing enough power.
BmoreBateman
Nov 08, 2019Guide
Hey thanks for the reply. I have done a channel scan and verified that channel 8 was empty on 2.4Ghz so I'm using that, 136 on 5Ghz. I live in a townhome complex so i have alot of people near by. I can see 40 devices when I did my Channel scan.
Beamforming was on by default and i toggled the 20/40 Coexistence with no success.
Smart connect is on currently.
Netduma-Fraser
Nov 08, 2019NetDuma Partner
Just to confirm your disabled QoS completely from the Anti-Bufferbloat 3 line menu and still suffering from slow speeds? What speeds do you get when you're using a wired connection? Disable smart connect and connect to 5GHz manually, are the speeds still slower?
- BmoreBatemanNov 08, 2019Guide
Yes I disabled QoS completely.
I am normally pulling 850Mbps from Fast.com on a wired connection
I just got home and disabled smart connect and wow im seeing such a difference.when its on, sometimes not loading pages to the best of 30Mbps (not consistant) and when its off I am suddenly getting 640Mbps.
Why would smart connect/my 2.4Ghz be having such a issue? its the only one in its channel and i see this on the channel wireless scan
Channel 4; Rssi -16; Noise -87 and 40MHz (coexistence is off at the moment)
- Netduma-FraserNov 08, 2019NetDuma PartnerAhh that's great news. Some devices don't work well with the automatic switching that smart connect offers. It could also be that the router isn't detecting the proper bandwidth needs of the device. Definitely keep it off. 2.4GHz should now work better but you won't get as high speeds but it's good over long distances. 5GHz should get you much higher speeds but works better over shorter ranges.
- BmoreBatemanNov 11, 2019Guide
So I left this open to see if it was long term fixed, It is not. it happened once again and it looks like the router just completely stops working with the 5GHz network. I disabled the Smart Connect and had everything connecting to it manually. It eventually just got to the point that I could see the network but everything kept failing to sign in (kept saying the password was incorrect) and When I opened it Completely so there was no password, It just kept failing to connect. I then reset the the router using the button on the back again and left it default it just stops working with the 5GHz channel. I tested this by connecting my range extender and told it to use both the 2.4 and 5GHz but it cant connect to the 5GHz channel at all.
