UnknownSith's avatar
UnknownSith
Apprentice
Feb 15, 2020
Xr500 WiFi speed drop
I have an xr500 that has recently started having slower WiFi issues. I have reset the router via the reset button on the back which helped initially but the problem returned. I’ve included a photo of the speed drop before and after. I’m looking for any help to resolve this.
  • Turned out to be a kinked Ethernet cable that was only allowing a set download speed of 93 mbps. Now all ok with a new cable.
1 Reply
