Ziptie
Dec 07, 2018Aspirant
XR500 Wifi speeds very slow
I've tried everything this forum mentioned
Turn off QoS, turn of data sharing, wifi setup with Dumas, Set MAC address to previous router and nothing worked
Qos is set 300 up and 300 down 100% ...
Netduma-Fraser
Dec 07, 2018NetDuma Partner
Turn off Smart Connect and connect to the 5GHz, what do you get with that?
Also download a WiFi analyser and change it to the least congested channel. Weird though that the down on wireless is the only thing affected
