Ziptie
Dec 07, 2018Aspirant
XR500 Wifi speeds very slow
I've tried everything this forum mentioned
Turn off QoS, turn of data sharing, wifi setup with Dumas, Set MAC address to previous router and nothing worked
Qos is set 300 up and 300 down 100% ...
Ziptie
Dec 09, 2018Aspirant
300mb down 300mb up
and I get 120down 290-300 up on wifi 5G
300 down 300 up if I connect via ethernet to XR500
i've tried it all that I could ... please help
Netduma_Jack
Dec 11, 2018NetDuma Partner
That's so weird. It's just your download speed that's slow over WiFi? Everything else is hitting expected speeds i.e. LAN, upload over WiFi?
Is there anything using the connection at the same time that could be slowing this down?
In >QoS >Anti-Bufferbloat, have you set your max speeds to 300mbps in the Antu-Bufferbloat settings?
