sero7onin
Jul 16, 2018Aspirant
XR500 wired ethernet connection slower than 5G wifi
Hello everyone,
I really do like the XR500 and its features, thats why I planned to use it as the router in my home network. Since like forever wired connections are better than wifi conne...
Netduma-Fraser
Jul 16, 2018NetDuma Partner
Hi sero, have you tested every single LAN port on the XR500 to check if you have a faulty port?
