lexrst
Jul 28, 2020Tutor
XR500 wired/wireless speed degrades after a short amount of time
My speeds degrade over a short period of time. 3 computers are wired and 1 wireless. Modem>Router>Computers nothing special. Both the modem and router are brand new 4 months. Computer direct to m...
Netduma-Fraser
Jul 29, 2020NetDuma Partner
Do the speeds slowdown for both wired and wireless devices? When it next happens if you go to the setup wizard from settings and just go as far as the speedtest what results do you get? How have you disabled QoS exactly?
lexrst
Jul 29, 2020Tutor
Yes both wired and wireless will slow down. I will have to check the wizard for the speeds, I run the speedtest from speedtest.net to get my results and will be as low as 5Mbps down and about the same up. I have Gigablast from Cox so I get around 700 - 900 depending on what we have running and what is going on with cox on average. Running a test from the router I get 459 down and 33 up. speedtest.net gave me 661 down and 16 up. when I wake up in the morning and do a test it will be down to 5 at the lowest that I have seen. If I then reboot it it will take me back up to normal speeds. For QoS I went under it and selected never under Anti-Bufferbloat, when I go into it, it will say All QoS features are disabled.
