JPW162
Mar 28, 2023Aspirant
XR500 Wireguard
I can get the hybrid vpn working with openvpn however can't seem to get wireguard going, should it work? I was planning to use surfshark as the vpn provider. - if the xr500 isn't working with wiregu...
Netduma-Fraser
Mar 28, 2023NetDuma Partner
Which firmware version are you currently on? Do you actually see the Wireguard option under the Advanced Setup on HybridVPN?
If you were to flash another software you would not be able to get back to DumaOS and it would invalidate your warranty so it isn't advised.
JPW162
XR500 V2.3.2.134
[Interface]
Address = 10.14.0.2/16
PrivateKey = ---
DNS = 162.252.172.57, 149.154.159.92
[Peer]
PublicKey = ---
AllowedIPs = 0.0.0.0/0
Endpoint = 84.39.114.157:51820
am I missing something? - can't seem to find the wireguard option sorry!
- Netduma-FraserMar 30, 2023NetDuma PartnerAh okay, it's not implemented currently, you would see it at the top of the config box with a menu for VPN Type to switch between OpenVPN and Wireguard. You'll have to continue using OpenVPN for the moment.
- JPW162Mar 30, 2023Aspirant
is there any beta/alpha firmware in which it is implemented? It sounds like you were expecting it to already be there!
- Netduma-FraserMar 30, 2023NetDuma PartnerPerceptive! It's not currently available and it was something we were working on but it was causing some pretty major issues, if we can resolve them then it will be implemented. If not then it might be something we have to defer.
