JPW162
Mar 28, 2023Aspirant
XR500 Wireguard
I can get the hybrid vpn working with openvpn however can't seem to get wireguard going, should it work? I was planning to use surfshark as the vpn provider. - if the xr500 isn't working with wiregu...
JPW162
Mar 30, 2023Aspirant
is there any beta/alpha firmware in which it is implemented? It sounds like you were expecting it to already be there!
Netduma-Fraser
Mar 30, 2023NetDuma Partner
Perceptive! It's not currently available and it was something we were working on but it was causing some pretty major issues, if we can resolve them then it will be implemented. If not then it might be something we have to defer.
