JPW162
Mar 28, 2023Aspirant
XR500 Wireguard
I can get the hybrid vpn working with openvpn however can't seem to get wireguard going, should it work? I was planning to use surfshark as the vpn provider. - if the xr500 isn't working with wiregu...
JackeyPL
Dec 13, 2024Aspirant
Great, I bought this router because I had read dumaos supports wireguard and netgear developers stated in 2022 it's almost ready... we have almost 2025, any progress?
Netduma-Fraser
Dec 14, 2024NetDuma Partner
I know you've posted on our forum and I'll respond there also but there were a lot of issues with integrating it so much so that we decided to postpone it. That was about a year ago and since then we've updated to DumaOS 4 which the XR range won't get unfortunately.
