jmc7
Apr 08, 2018Guide
XR500 Wireless ACL - missing
Hi all, As I continue to configure the router, I realized the wireless acl is missing under advanced wireless settings. Was this function removed in the latest firmware version v2.2.1.10?
Netduma-Fraser
Apr 08, 2018NetDuma Partner
Yes I believe it was, instead you can use the Device Manager to block any devices.
jmc7
Apr 08, 2018Guide
Sad to hear this was removed. One reason for purchasing this router was due to having this ACL setting. Is it possible to obtain a previous firmware that still have this feature?
