W1lliam
Jul 11, 2018Virtuoso
XR500 Wireless Region Issue
My friend bought me a XR500 from Japan and I am not being able to change its Wireless Region to my country, anyway I can request for region reset? Thanks
William
- Jul 11, 2018I don't think it's possible, would suggest contacting the Netgear phone line. Otherwise look up the allowed channels in your country and make sure you manually select those.
Netduma-Fraser
Jul 11, 2018NetDuma Partner
I don't think this is possible as they are region locked to prevent people using different channels in their country that are legally not allowed.
- W1lliamJul 11, 2018Virtuoso
That is the reason I am asking for help to change the wireless region from Japan over Taiwan, not trying to make any illegal use, thanks
- Netduma-FraserJul 11, 2018NetDuma PartnerI don't think it's possible, would suggest contacting the Netgear phone line. Otherwise look up the allowed channels in your country and make sure you manually select those.
thank you for the advice.
William
