JHickey4425's avatar
Jun 14, 2018
XR500 with Chromecast and gaming
I just purchased the XR500 and have watched multiple videos on the set up of the device as well as reading the helpful tips to prevent lag throughout the gaming experience.
What I want to know is why is my Chromecast using all the bandwidth EVEN THOUGH I've done these few things...
I've set the "traffic prioritization" for the PS4.
Bandwidth Allocation : 54% which allows for 51mbps to the console.
Anti-Bufferbloat : 80% (I've tinkered with different numbers such as the helpful tip of 70%) which still creates this issue. Also, the chromecast as well as the phone it is pulling from are set at 5% (barely enough juice to allow 1080p).
Any suggestions or solutions?
  • I apologize...the issue I'm having is based around the PS4 lagging significantly when the chromecast is turned on.
    Through my network monitoring it is using significantly more than my ps4 and is hogging about 2/3rds of the bandwidth total.
    I have my anti-bufferbloat selected to Always as well.
    • Netduma-Fraser's avatar
      Netduma-Fraser
      NetDuma Partner
      What is your physical setup? It sounds like the XR500 doesn't have full control over devices otherwise your settings would work.
      Remove manual rule for PS4 in Traffic Prioritization and keep DumaOS Classified Games enabled, it covers consoles also. The PS4 definitely doesn't need that big a chunk of bandwidth, games use less than 1mbps. I'd reallocate your percentages and then disable Share Excess in the download/upload of bandwidth allocation. That will ensure the devices can never take more than you've allocated.
      • JHickey4425's avatar
        JHickey4425
        Tutor
        Okay.
        My physical setup is ps4 connected ethernet. My chromecast is being casted from a samsung phone (which I did a little more research and found that some samsungs have bad bursts of packets coming through). However, upon looking into the chromecast a little bit more. My buffering issue did not go away when I allocated a little more than just the 8mpbs that it states for 1080p.
        So, in theory what you're saying Netduma-Fraser is I should reallocate the %s back to normal distribution? Does that work well enough? I just want to ensure we're not having issues while playing PS4. I also want to be able to have my chromecasts work simultaneously as my fiance likes to watch netflix if she's upstairs.
        My download is 120mbps and upload is 13mpbs with 15-30ping Case850
  • Download isn't as much of a concern as the upload is. I'd make sure the PS4 has at least 1Mb upload allocated to it. Not having a steady bandwidth for upload could cause lag.
    I have both my Xbox Ones set with default download allocation and set upload to 1Mb allocation on each Xbox.
    Don't have any lag issues except with Elder Scrolls online but that's because of how large the game is and the high player count.
