Mike40
Aug 13, 2023Luminary
XR500 with CM1200 Call of Duty/Warzone PS5
I've had the XR500 and CM1200 for a couple of years now, but lately, I have noticed that I lag almost every game I get into. It doesn't matter if it's MP, Warzone, or DMZ. I play COD 99% of the tim...
Netduma-Fraser
Aug 13, 2023NetDuma Partner
When you're getting lag what is the average ping shown on the game and how does this compare to the Geo-Filter ping? There is also a beta version you can try: https://forum.netduma.com/topic/51611-new-xr500-beta-firmware-33535/
- Mike40Aug 13, 2023Luminary
Usually in-game I ping in the low 30s and the Geo-Filter pings in the low 20s. I'm not very tech-savvy, but I know that is a low ping. I can see the difference in-game and in the kill cam. I was playing Shipment earlier, walked around the corner then died by "invisible bullets". I watched the kill cam and saw the other person firing at me before I even saw them.
I will try the beta version and see if that improves anything.
- Netduma-FraserAug 14, 2023NetDuma PartnerThat doesn't seem like lag then but you may benefit from forcing different servers even if they're a bit further away with a slightly higher ping
- Mike40Aug 14, 2023Luminary
I've tried different servers but all with the same result. I have a match or two that there is no delay then it's back to the normal delay.
Is there anything I can do to get rid of the delay I keep getting?
