Mike40
Aug 13, 2023Luminary
XR500 with CM1200 Call of Duty/Warzone PS5
I've had the XR500 and CM1200 for a couple of years now, but lately, I have noticed that I lag almost every game I get into. It doesn't matter if it's MP, Warzone, or DMZ. I play COD 99% of the tim...
Mike40
Usually in-game I ping in the low 30s and the Geo-Filter pings in the low 20s. I'm not very tech-savvy, but I know that is a low ping. I can see the difference in-game and in the kill cam. I was playing Shipment earlier, walked around the corner then died by "invisible bullets". I watched the kill cam and saw the other person firing at me before I even saw them.
I will try the beta version and see if that improves anything.
Netduma-Fraser
Aug 14, 2023NetDuma Partner
That doesn't seem like lag then but you may benefit from forcing different servers even if they're a bit further away with a slightly higher ping
- Mike40Aug 14, 2023Luminary
I've tried different servers but all with the same result. I have a match or two that there is no delay then it's back to the normal delay.
Is there anything I can do to get rid of the delay I keep getting?
- Netduma-FraserAug 15, 2023NetDuma PartnerIf nothing has changed on your end when you get those games without the delay then it sounds like it's an issue with the game. Best thing to do would be to add any servers you have a bad experience to your deny list so you don't play on them again during your next gaming session. After repeating this you should be left with the servers you know play well for you.
