Pallywood
Apr 14, 2020Tutor
XR500 with EX7700 and Imac
Hello I recently revived an Imac. The Wifi network card that is uses is a Atheros 9380. The extender is connected via an ethernet cable. When the imac is near the Xr500 I can only get speed up ...
Netduma-Fraser
Apr 14, 2020NetDuma Partner
As above, disable Smart Connect on the XR and then connect to 5GHz and see if you get faster speeds.
Pallywood
Apr 15, 2020Tutor
For now I have turned off the Wifi on the router and I am connectingg via the extender. The speed is up to 125Mgbs now.
The extender in in another room./)
I dont see an option on the Imac wifi settings to choose the wifi frequecy. ( is that because smart connect is turned on)
Thanks
James
- plemansApr 15, 2020Guru - Experienced User
When you're using smart connect, the extender or router (depending on which connected to) band steers. That means it moves devices between 2.4ghz and 5ghz as needed.
- Netduma-FraserApr 15, 2020NetDuma PartnerHave you ever been able to get close to the speeds the phone is getting with the iMac on any other router? It may be that the WiFi card is not strong enough.
- PallywoodApr 15, 2020Tutor
Netduma-Fraser wrote:
Have you ever been able to get close to the speeds the phone is getting with the iMac on any other router? It may be that the WiFi card is not strong enough.The maximum theoretical speed on this card is 300, So 250 is is fine next the the extender.
The trouble was that I was getting just 60 next to the router. For now I have turned the wifi off on the router and I am connecting via the extender and I am getting around 130 so that is a big improvement.
Thanks
