RaleighEd's avatar
RaleighEd
XR500 with HybridVPN and NordVPN
Not able to get NordVPN with their OpenVPN config file to run successfully. I copied the config file, etc. as described. The information shows that the status is connected, but when I check for a DNS leak, it shows that the connection isn't secure.
The VPN runs properly on the computer, but I can't get it to run successfully on the router with HybridVPN.
Thanks,
Ed
  • Hi Ed - just to repost my reply in your other thread, this will be fixed in the next firmware.
    • nickstanton's avatar
      nickstanton
      Tutor
      has this been resolved? i can't figure out how to connect Nord and my xr500
      • Netduma-Fraser's avatar
        Netduma-Fraser
        NetDuma Partner
        Hi Nick, are you using an OpenVPN config file from Nord and putting it in the advanced setup of the VPN Hybrid?
