RaleighEd
Feb 05, 2019Aspirant
XR500 with HybridVPN and NordVPN
Not able to get NordVPN with their OpenVPN config file to run successfully. I copied the config file, etc. as described. The information shows that the status is connected, but when I check for a DNS...
Netduma_Alex
Aug 30, 2019NetDuma Partner
The leaking is a known bug. You can tell if the VPN's working at all by asking Google where your IP places you.
Nightfall1293
Aug 30, 2019Aspirant
Yes it still places me at my correct location it is not working properly.
- Netduma-FraserAug 31, 2019NetDuma PartnerIt should show on Google, delete your browser cache and check other IP sites as well, may just be cached.
- Nightfall1293Aug 31, 2019AspirantNope not coached cleared all history and cache and checked on multiple devices including smart phone, game console, desktop, and laptop all still show my ISP ip address.
- Netduma-FraserAug 31, 2019NetDuma PartnerHow have you setup the VPN Traffic Panel? Have you added any devices?
