Rossco88
Dec 13, 2018Aspirant
XR500 with Telstra NBN FTTN
I just got a XR500 and tried setting up with the Telstra gateway modem in bridge mode on my Telstra FTTN NBN connection with zero luck
Wondering if anyone has this router working on a telst...
Rossco88
Correct the reason for the bridge is to avoid double NAT, DMZ could be an option would have to give it a go, not the ideal option. I know the Draytek Vigor 130 works well in bridge mode but I also know that Telstra uses IPoE while other ISP's use PPPoE
Netduma_Jack
Dec 13, 2018NetDuma Partner
Give it a go - if you get Open NAT through using DMZ, and bandwidth speeds remain high - then your setup is great.
