FeuerFrei111
Dec 01, 2021Guide
XR500 Won't Connect to Company VPN (GlobalProtect)
Netgear Community, As the name implies, my XR500 won't connect to my company VPN of GlobalProtect. When trying to connect, GlobalProtect states: "Gateway access.XXXXXXXX.com: The network connecti...
Netduma-Fraser
Dec 01, 2021NetDuma Partner
Try the following:
Set NAT to Open in WAN Settings
Disable QoS completely from the Congestion Control 3 horizontal line icon menu
If needed make a Traffic Controller rule to allow ALL traffic to the device
Then see if it works.
- FeuerFrei111Dec 03, 2021Guide
Netduma-Fraser,
Thank you for the reply. I made all 3 changes, APPLY, and still no luck.
- Netduma-FraserDec 03, 2021NetDuma PartnerJust for a test put the device in the DMZ and see if it works, either way then remove it as it is a security risk.
- plemansDec 03, 2021Guru - Experienced User
I didn't see a zhone modem/gateway with that model. But most of the models I seen from Zhone were gateways with integrated routers.
Is the zhone in passthrough/modem only mode? Or do you have the xr500's IP address in the zhones DMZ?
