Albo718
Jun 16, 2019Aspirant
XR500 won't connect to Internet
Netduma_Alex
Jun 17, 2019NetDuma Partner
Gonna need some more information. What's your network setup? What modem are you using? Is the modem connected to the WAN port of the XR500? Could you get internet with a previous router? Does the modem get a connection on it's own? Have you gone through the setup wizard of the XR500 to find the right connection type? If you need PPPoE, do you know your ISP's login info?
Albo718
Jun 20, 2019Aspirant
Hey Alex,
I tried bridge mode on my verizion fios g1100 router. It connected fine to the netgear router but still no internet. I removed the Netgear router, reset my Verizon router and it still works and gets Internet.
- FURRYe38Jun 21, 2019Guru - Experienced User
Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the NG router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ/ExposedHost or IP Pass-Through for the IP address the NG router gets from the modem.
