Albo718
Jun 16, 2019Aspirant
XR500 won't connect to the Internet with FIOS
My wife bought me an XR500 becuase the FIOS G1100 router is so much worse than we had with cable. I can't get the XR500 to connect to the Internet. I have had Verizon tech support release the DCHP ...
Netduma-Fraser
Jun 16, 2019NetDuma Partner
Do you know if you require PPPoE or VLAN in order to gain a connection? If you're not sure I would suggest looking at the G1100 router WAN settings and see if it's set to anything other than default, if so input those settings into the XR500. I assume you went through the setup wizard when plugging in the XR500 for the first time?
- Albo718Jun 16, 2019Aspirant
I'm not sure about PPPoE or VLAN. I looked in the Fios Router settings but I'm not sure where to find those options. I did the router setup wizard a couple times. It fails at the Internet bandwidth check (the 3rd or 4th step). I tried to skip that but it didn't help.
- Netduma-FraserJun 16, 2019NetDuma PartnerWhat is the exact setup at the moment as usually you do require the ONT to be on and then a router plugged into that in order to get a connection.
It is just the standard Verizon FIOS setup I think. Ethernet from ONT to the G1100 Router. I've seen directions on the web to make the G1100 a Bridge to the XR500. Maybe I should try that and just leave the G1100 in the mix?
