RPatrick
Sep 16, 2022Aspirant
XR500 wont let modem set IP
When the net goes out and I have to do the typical unplug and plug back in routine this odd thing is happening... All settings in the router are correctly set to let the ISP set the IP addresses dy...
Kitsap
Sep 16, 2022Master
All settings in the router are correctly set to let the ISP set the IP addresses dynamically
If I reboot the modem first, then the router, the local network goes up just fine but I get no internet.
If I reboot the router first, then the modem, I get internet but it's temporary and often flakey. My ISP tech support says that the router isn't accepting the ip changes dynamically for some reason and when the router trys to dictate the modem things don't work right.
Has anyone experiences this and if so, how did you fix it?
What is the manufacturers name and model number of the modem/optical network terminal you have in front of your XR500?
Are you sure it is not a combination device that includes a router?
