RPatrick
Sep 16, 2022Aspirant
XR500 wont let modem set IP
When the net goes out and I have to do the typical unplug and plug back in routine this odd thing is happening... All settings in the router are correctly set to let the ISP set the IP addresses dy...
michaelkenward
Sep 17, 2022Guru - Experienced User
RPatrick wrote:
My ISP tech support says that the router isn't accepting the ip changes dynamically for some reason and when the router trys to dictate the modem things don't work right.
Sounds like the usual meaningless ISP tech support b*ll*cks.
Which ISP? Might help people to avoid it.
