cosmo2450
Jun 08, 2020Guide
xr500 x2
I have two xr500 and the network looks like this: mesh extender (in garage) / INTERNET---(cable)->--xr500mid---(cabl...
Netduma-Fraser
Jun 09, 2020NetDuma Partner
I assume you're using routerlogin.net to do this, if you access via the LAN IP then you should be able to access the interface of the one in router mode.
- cosmo2450Jun 09, 2020GuideThat was it. Thank you very much
