crj83
Mar 27, 2018Aspirant
xr500 xbox disconected
Hello i got the xr500 last week and everday i have to reboot the router as for some reason when i get up in the morning my xbox one won't conect to the internet i am only having the problem with the ...
Netduma-Fraser
Mar 28, 2018NetDuma Partner
It is likely the ethernet cable itself (try another if you have one). It could be the ethernet port on the Xbox also. If you connect wirelessly only that Xbox has the issue been resolved?
crj83
Mar 28, 2018Aspirant
Thanks for the advice but i highly doubt it as it only started to happen when i upgraded to this router. I don't get disconeted when playing it's only when the xbox is off over night
- Netduma-FraserMar 28, 2018NetDuma PartnerTry:
Different ethernet cable
Connecting via WiFi
If the Xbox is using Instant On, disable that and see if it continues
