crj83
Mar 27, 2018Aspirant
xr500 xbox disconected
Hello i got the xr500 last week and everday i have to reboot the router as for some reason when i get up in the morning my xbox one won't conect to the internet i am only having the problem with the ...
crj83
Mar 28, 2018Aspirant
Thanks for the advice but i highly doubt it as it only started to happen when i upgraded to this router. I don't get disconeted when playing it's only when the xbox is off over night
Netduma-Fraser
Mar 28, 2018NetDuma Partner
Try:
Different ethernet cable
Connecting via WiFi
If the Xbox is using Instant On, disable that and see if it continues
Connecting via WiFi
