crj83
Mar 27, 2018Aspirant
xr500 xbox disconected
Hello i got the xr500 last week and everday i have to reboot the router as for some reason when i get up in the morning my xbox one won't conect to the internet i am only having the problem with the ...
crj83
Mar 29, 2018Aspirant
I am turning the xbox of by the controller and the xbox is set up for instant on. I can be on and off the xbox all day with no problems then when i wae up in the morning i get no iternet to the xbox
Netduma-Fraser
Mar 29, 2018NetDuma Partner
If you set it to energy saving do you get the same issue?
- crj83Mar 29, 2018Aspirant
I don't know but it shound not make a differance as the only thing i have changed is the router never had this problem befor i got this router
- Netduma-FraserMar 29, 2018NetDuma PartnerCan you see if that fixes the issue please. If it does then it indicates Instant On isn't connecting with the router from sleep for some reason.
