crj83
Mar 27, 2018Aspirant
xr500 xbox disconected
Hello i got the xr500 last week and everday i have to reboot the router as for some reason when i get up in the morning my xbox one won't conect to the internet i am only having the problem with the ...
Netduma-Fraser
Mar 29, 2018NetDuma Partner
That's what I want to double check, then we can get the Devs involved to see why that's occurring.
Kirill83Rus
Mar 30, 2018Aspirant
Geo Filter not working in Russian on Xbox One absolutly.Why????????
- Netduma-FraserMar 30, 2018NetDuma PartnerHi Kirill, could you make a new topic for your issue please as these two issues are unrelated.
Also just quickly it depends on what game you're playing and where their servers are located, you may need to expand your radius to encompass more of Europe. - crj83Mar 31, 2018Aspirant
Sorry for the delay i wanted to give it a couple of days to see if it worked putting it in energy saving mode seems to have sorted it out. I did not won't to conect wirelessly wired is allways best i was told
- XRaptor29Mar 31, 2018LuminaryYes wired is preferred for gaming. Are you running an Xbox Insider build?
i don't know how can i tell
- XRaptor29Mar 31, 2018LuminaryIt's something you sign up for. Since you don't know, more than likely you're not on an insider build. I was curious if it needed to reported as a bug or not.
- crj83Apr 01, 2018Aspirant
i do get xbox insider stuff
- Netduma-FraserApr 01, 2018NetDuma PartnerGreat thanks for letting us know that it resolved your issue. It could be related to the power mode but could be related to Xbox Insider as well, every time I used it I had crazy bugs
