crj83
Mar 27, 2018Aspirant
xr500 xbox disconected
Hello i got the xr500 last week and everday i have to reboot the router as for some reason when i get up in the morning my xbox one won't conect to the internet i am only having the problem with the ...
crj83
Mar 31, 2018Aspirant
Sorry for the delay i wanted to give it a couple of days to see if it worked putting it in energy saving mode seems to have sorted it out. I did not won't to conect wirelessly wired is allways best i was told
XRaptor29
Mar 31, 2018Luminary
Yes wired is preferred for gaming. Are you running an Xbox Insider build?
- crj83Mar 31, 2018Aspirant
i don't know how can i tell
- XRaptor29Mar 31, 2018LuminaryIt's something you sign up for. Since you don't know, more than likely you're not on an insider build. I was curious if it needed to reported as a bug or not.
- crj83Apr 01, 2018Aspirant
i do get xbox insider stuff
- Netduma-FraserApr 01, 2018NetDuma PartnerGreat thanks for letting us know that it resolved your issue. It could be related to the power mode but could be related to Xbox Insider as well, every time I used it I had crazy bugs
