crj83
Mar 27, 2018Aspirant
xr500 xbox disconected
Hello i got the xr500 last week and everday i have to reboot the router as for some reason when i get up in the morning my xbox one won't conect to the internet i am only having the problem with the ...
ericwgriffin194
Jul 09, 2018Tutor
Very helpful: I have been on another topic thread about total internet drops. My xr500 router, sometimes multiple times a day but usually once overnight, loses connection with my modem. I have received many tips from this thread & spent countless hours on phone with NG support. I left my Xbox disconnected from xr500, and you guessed it, no internet router drops!
I’ll try the instant on adjustment next. Maybe a 2nd switch. Thx!
CBayes
Aug 23, 2018Aspirant
I have the same issue, all devices that I have connected wired have issues and all wireless devices are fine. I have to restart my router and the issue resolves until the next couple of days when I try to log back in. This issue is on all wired devices not just my 2 consoles, anyone have any advice?
- FURRYe38Aug 23, 2018Guru - Experienced User
Have you set up IP address reservations for your consoles?
My XR450 went online today with my two XB1s, both wired. NAT Filter set to OPEN. IP address reserved at 192.168.1.198 and 199. DHCP IP address pool set for 100 thru 200.
DNS Quad 1 and 9
CBayes wrote:
I have the same issue, all devices that I have connected wired have issues and all wireless devices are fine. I have to restart my router and the issue resolves until the next couple of days when I try to log back in. This issue is on all wired devices not just my 2 consoles, anyone have any advice? - Netduma_JackAug 25, 2018NetDuma PartnerCBayes - are you on the trial firmware that fixes wired disconnects? I’ll PM you now with a link to file if not.
