Death652
Jul 11, 2018Tutor
Xr500 Xbox double nat and bridging the modem
When ever I connect my Xbox through a wired connection I get a double nat, I bridged my modem/router combo which is a arris, this fixed the nat problem but then I am unable to connect to the xr500’s ...
- Jul 12, 2018You should be able to, give the router a reboot as should be no reason you can't unless the tablet is prioritizing data over WiFi
Death652
Jul 12, 2018Tutor
After I bridged the modem I was connected to the xr500 but when I tried to access the interface using www.routerlogin.com and www.routerlogin.net wirelessly on a tablet I couldn’t, but doing the same thing with wired connections works.
Before I bridged the modem using www.routerlogin.com and www.routerlogin.net worked on the same tablet and any device wirelessly.
Netduma-Fraser
Jul 12, 2018NetDuma Partner
If you're bridged then the WiFi will be disabled on the gateway so thats why you can't access it
- Death652Jul 12, 2018Tutor
I know the WIFI is disabled on the modem/router Arris because it’s bridged but on the xr500 I can connect to the internet wirelessly, but I couldn’t access the duma OS Interface wirelessly.
So if I bridge the modem/router combo the xr500 is connected to then I can’t access the duma OS interface wirelessly?
- Netduma-FraserJul 12, 2018NetDuma PartnerYou should be able to, give the router a reboot as should be no reason you can't unless the tablet is prioritizing data over WiFi
