Death652's avatar
Jul 11, 2018
Xr500 Xbox double nat and bridging the modem
When ever I connect my Xbox through a wired connection I get a double nat, I bridged my modem/router combo which is a arris, this fixed the nat problem but then I am unable to connect to the xr500’s ...
  • Netduma-Fraser's avatar
    Netduma-Fraser
    Jul 12, 2018
    You should be able to, give the router a reboot as should be no reason you can't unless the tablet is prioritizing data over WiFi
