StephenMaye
May 02, 2018Tutor
Xr500 Xbox nat type
New owner and first time poster here, i have just gotten my hands on the Xr500 and am having a terrible time getting my Xbox one X out of strict nat type. First i had strict double nat but was able to...
- May 02, 2018Thanks for the reply Fraser, yes the xr500 is in my bell home hub dmz as that’s how I was able to remove the double nat, and the Xbox has a static ip.. I wasn’t able to figure out how to access the dmz settings on the xr500 to add the Xbox.
Netduma-Fraser
May 02, 2018NetDuma Partner
Hi Stephen, if the XR500 WAN IP found in System Information is in the DMZ of your Bell Home Hub then set a static IP for the Xbox on the XR500 and then put the Xbox IP in the DMZ of the XR500. That should open your NAT.
- StephenMayeMay 02, 2018TutorThanks for the reply Fraser, yes the xr500 is in my bell home hub dmz as that’s how I was able to remove the double nat, and the Xbox has a static ip.. I wasn’t able to figure out how to access the dmz settings on the xr500 to add the Xbox.
- Netduma-FraserMay 02, 2018NetDuma PartnerYou can find it in Settings > Setup > WAN Setup
