Jayrod215
May 04, 2019Aspirant
XR500 Xbox One Wired Disconnect After Inactivity
I have my XR500 wired to my Xbox One, and it works fine, until I put my xbox in standby for a while, and then when I turn it back on it will be disconnected from the internet, and the only way to fix...
additude
May 04, 2019Virtuoso
"that they didn't fix it in QA and can't reproduce and fix it a year later?" .... unfortunately... the answer is yes....
I have had similiar issues on my LAN's in the past. Mostly with Printers that I do not use frequently and when I went to print on them they were not responsive. So what I have done is, and this may apply to your case as well, is that on my home automation server I set it up to run a "Scene" every hour that pings the printers IP address. The ping is a "Keep Alive" in it's own way.
I have also setup similar pings in Visual Basic. Create a "batch" file, it's not hard to do, then let task scheduler or cron ping the device on ocassion.
It may even be possible to run a bash script in the router itself to ping the XBOX....
For something so simple, it can be created in C++ as well....
- Netduma-FraserMay 04, 2019NetDuma Partneradditude, have you tried the hotfix firmware to see if that resolves your issue. That's a clever workaround!
- schumakuMay 04, 2019Guru - Experienced User
Look here -> How do I fix disconnection issues with my Xbox One console when connected to Nighthawk Pro Gaming router?
- Jayrod215May 04, 2019Aspirant
I understand that that might be a workaround, but is highly inconvenient for two reasons: one, it disables automatic idle updates on the xbox, that can sometimes take hours, and two, it makes the bootup time a couple minutes instead of a couple seconds. Modifying how my clients work is not a solution to a problem with the router.
I have also installed the hotfix firmware. Waiting to see if the issue continues.
In regards to the script that pings the other hosts every so often, I don't have any hosts on my network that are on and running 24 hours a day.
- Netduma-FraserMay 04, 2019NetDuma PartnerPlease keep us updated on if the hot fix firmware works, it’ll be important feedback for the developers
