Jayrod215
May 04, 2019Aspirant
XR500 Xbox One Wired Disconnect After Inactivity
I have my XR500 wired to my Xbox One, and it works fine, until I put my xbox in standby for a while, and then when I turn it back on it will be disconnected from the internet, and the only way to fix...
additude
May 04, 2019Virtuoso
"that they didn't fix it in QA and can't reproduce and fix it a year later?" .... unfortunately... the answer is yes....
I have had similiar issues on my LAN's in the past. Mostly with Printers that I do not use frequently and when I went to print on them they were not responsive. So what I have done is, and this may apply to your case as well, is that on my home automation server I set it up to run a "Scene" every hour that pings the printers IP address. The ping is a "Keep Alive" in it's own way.
I have also setup similar pings in Visual Basic. Create a "batch" file, it's not hard to do, then let task scheduler or cron ping the device on ocassion.
It may even be possible to run a bash script in the router itself to ping the XBOX....
For something so simple, it can be created in C++ as well....
Netduma-Fraser
May 04, 2019NetDuma Partner
additude, have you tried the hotfix firmware to see if that resolves your issue. That's a clever workaround!
