Jayrod215
May 04, 2019Aspirant
XR500 Xbox One Wired Disconnect After Inactivity
I have my XR500 wired to my Xbox One, and it works fine, until I put my xbox in standby for a while, and then when I turn it back on it will be disconnected from the internet, and the only way to fix...
schumaku
May 04, 2019Guru - Experienced User
Look here -> How do I fix disconnection issues with my Xbox One console when connected to Nighthawk Pro Gaming router?
Jayrod215
I understand that that might be a workaround, but is highly inconvenient for two reasons: one, it disables automatic idle updates on the xbox, that can sometimes take hours, and two, it makes the bootup time a couple minutes instead of a couple seconds. Modifying how my clients work is not a solution to a problem with the router.
I have also installed the hotfix firmware. Waiting to see if the issue continues.
In regards to the script that pings the other hosts every so often, I don't have any hosts on my network that are on and running 24 hours a day.
- Netduma-FraserMay 04, 2019NetDuma PartnerPlease keep us updated on if the hot fix firmware works, it’ll be important feedback for the developers
- Jayrod215May 05, 2019Aspirant
Hotfix patch did not change anything
- Netduma-FraserMay 05, 2019NetDuma PartnerYou've already suffered a disconnection with the same characteristics as the issue before? Did you factory reset after the upgrade to make sure there were no legacy issues from the previous firmware?
