Jayrod215
May 04, 2019Aspirant
XR500 Xbox One Wired Disconnect After Inactivity
I have my XR500 wired to my Xbox One, and it works fine, until I put my xbox in standby for a while, and then when I turn it back on it will be disconnected from the internet, and the only way to fix...
Jayrod215
May 06, 2019Aspirant
Yes, I factory reset my router after installing the hotfix patch. Issue remains. I never had an issue with instant on on my NG R7000 I swapped out for this XR500. Its not the Xbox's fault.
schumaku
May 07, 2019Guru - Experienced User
The R7000 buit-in switch was and is very basic compared to the QCA8337 which does support IEEE 802.3az Energy Efficient Ethernet, can go to different LPI modes for both 100BASE-Tx EEE (requires asymmetrical operation, meaning each link partner to enter the LPI
mode independent of the other partner.) and 1000BASE-T EEE requires symmetrical operation, meaning both link partners must enter the LPI mode simultaneously. That's why both ends are coming into the play.
