gbassanini
Jan 10, 2020Follower
Xr500 xbox one x disconnects
I have an Xbox one X hard wired to XR500 but it keeps getting disconnected even after setting “energy saver” mode on xbox power settings. It happened to my xbox one as well and thought it was an issue...
Netduma-Fraser
Jan 11, 2020NetDuma Partner
Is this happening on all your devices? Is it definitely the internet disconnecting or is it the game being disconnected from? Does the disconnection happen when you're playing or when you next go to play the console is offline?
