MikeCompetillo
Feb 01, 2019Guide
XR500 Xbox One X issue
I was previously running off wireless for my Xbox one X, but then ran into lag issues (which I blame the Xbox wifi card for). I finally then ran a cable to my xbox (100ft away), and it seemed to work...
MikeCompetillo
Feb 01, 2019Guide
Ah Figures it was MS... Do you know if the Insider Aplha Xbox releases fixes this issue? I'm hoping to try a switch in between to see if that fixes it.
Feb 01, 2019Guru - Experienced User
I don't know for sure. My roommates box is on the Preview program. His is disabled however I can check to see. Something i'll try this weekend.
- MikeCompetilloFeb 01, 2019Guide
Ok thanks! I just put a gigabit switch in between the router and xbox, and that seems to have fixed it. Guess that's my workaround for now.
- FURRYe38Feb 01, 2019Guru - Experienced User
Kewl, that works too. I'll enable the roommates feature has his is directly connected to the router.
Gb switches are good things.
