jeremyg237
Apr 06, 2018Luminary
XR500 XBOX PUBG best settings
Just got the router yesterday. Cant seem to find a good GEO filter for PUBG xbox. I live on the east coast (Virginia). Are there any servers in my area or do I need to put the circle around the whole...
jeremyg237
Apr 07, 2018Luminary
Why would I hook my PC to GEO filter, since I am playing PUBG on xbox?
XRaptor29
On the Geo filter, go to the menu and uncheck the strict mode. See if that works. PUBG might be one of those games like destiny where it needs that unchecked.
- jeremyg237Apr 07, 2018Luminary
I am an orginal NETDUMA R1 owner. I stopped using it because of the wifi. But if I cant use the geo filter then what is the point. Now if there is only a dedicated server in cali that would make since. But I did not spend 300 for a router to do the same thing my R7000 did. Not trying to get snippy by any means but one game it will work and the next it wont. The geo filter is the only reason I bought it. Dont want to be connected to CALI 3000 miles away.
- Netduma_JackApr 07, 2018NetDuma PartnerSo in your experience, there are PUBG servers in Cali that you’re being connected to! If so, add your Xbox to the Geo-Filter and then set it to filtering mode, with your range set around the server location you prefer e.g. Ohio.
When you join the Cali server the router will block it, so you may need to restart the PUBG lobby to try again- jeremyg237Apr 09, 2018Luminary
Still having issues with the XBOX PUBG servers. Here are my settings.
1.My xbox one x is in the traffic priorization.
2. Filtering mode on.
3. Geo Filter mode Strict on.
4. I live in VA and my cirlce is set to 1348miles.
It gets finky. 1 game it will work and the next it will not. Any ideas?
