Mattyk25
Dec 24, 2021Aspirant
Xr500 Xbox series x high ping
I have 10-20 ms higher ping on my new Xbox series x compared to my Xbox series s. I use wired connection. I connected them both to same Ethernet cable testing each w the exact same connection. Is ther...
Mattyk25
Yes. But the ping from Xbox is the same ping I get when I play Pubg. Much higher on series x compared to series s. I can tell the difference when I play too
Netduma-Fraser
Dec 24, 2021NetDuma Partner
Are you using the Geo-Filter at all to force the servers you want? In WAN Settings set NAT to Open, that may help
- Mattyk25Dec 24, 2021AspirantNo geo-filter. Turned nat- open. No difference
- Netduma-FraserDec 24, 2021NetDuma PartnerUse the Geo-Filter as that is what will help you get lower ping games, what QoS settings are you using currently?
- Mattyk25Dec 24, 2021AspirantI tired geo filter. I play mostly pubg. I get connected to the same server every time. Download set to 83%
Upload set to 83%
Auto enable
Xbox 80
Everything else 1
