Mattyk25
Dec 24, 2021Aspirant
Xr500 Xbox series x high ping
I have 10-20 ms higher ping on my new Xbox series x compared to my Xbox series s. I use wired connection. I connected them both to same Ethernet cable testing each w the exact same connection. Is ther...
Netduma-Fraser
Dec 24, 2021NetDuma Partner
Are you using the Geo-Filter at all to force the servers you want? In WAN Settings set NAT to Open, that may help
Mattyk25
No geo-filter. Turned nat- open. No difference
- Netduma-FraserDec 24, 2021NetDuma PartnerUse the Geo-Filter as that is what will help you get lower ping games, what QoS settings are you using currently?
