Mattyk25
Dec 24, 2021Aspirant
Xr500 Xbox series x high ping
I have 10-20 ms higher ping on my new Xbox series x compared to my Xbox series s. I use wired connection. I connected them both to same Ethernet cable testing each w the exact same connection. Is ther...
Netduma-Fraser
Dec 26, 2021NetDuma Partner
Make a manual rule on Traffic Prioritization, source 1-65535, destination 1-65535 TCP/UDP normal, apply to wan, then check the ping please
Mattyk25
Dec 26, 2021Aspirant
38-36 ping after changes. Jumps to 45ish when plane flys overhead or a fun fight.
- Netduma-FraserDec 27, 2021NetDuma PartnerOkay so doesn't really appear to be a router issue as that rule prioritizes the entire console above every single device on your network, you could try putting the Xbox in the DMZ as well and see what it is then but if it's no different then it's definitely not on the router side
