morgan5634
Mar 26, 2019Tutor
Xr500 xbox showing offline on dumaOS
hopefully someone here can help
I have verizon fios for internet and the nighthawk gaming router is connected to that. when i log in to the dumaOS and set everything up my xbox shows offline in the...
morgan5634
Mar 26, 2019Tutor
also it does not show an ip address on the device manager page
Netduma-Fraser
Mar 26, 2019NetDuma Partner
If you reboot the router does it show as online then? Make sure the console is connected via automatic network settings.
- morgan5634Mar 26, 2019Tutor
ive tried rebooting it and the xbox. when i go to the device manager and click on the xbox it has a mac address but no ip address.
Netduma-Fraser wrote:
If you reboot the router does it show as online then? Make sure the console is connected via automatic network settings.- Netduma-FraserMar 26, 2019NetDuma PartnerWhat version of the firmware are you on? If you downgrade does it work as expected?
how do you down grade im on the latest. i couldnt find the down grade option
