morgan5634
Mar 26, 2019Tutor
Xr500 xbox showing offline on dumaOS
hopefully someone here can help
I have verizon fios for internet and the nighthawk gaming router is connected to that. when i log in to the dumaOS and set everything up my xbox shows offline in the...
Netduma-Fraser
Mar 26, 2019NetDuma Partner
If you reboot the router does it show as online then? Make sure the console is connected via automatic network settings.
morgan5634
Mar 26, 2019Tutor
ive tried rebooting it and the xbox. when i go to the device manager and click on the xbox it has a mac address but no ip address.
- Netduma-FraserMar 26, 2019NetDuma PartnerWhat version of the firmware are you on? If you downgrade does it work as expected?
- morgan5634Mar 26, 2019Tutor
how do you down grade im on the latest. i couldnt find the down grade option
What version of the firmware are you on? If you downgrade does it work as expected?- Netduma_JackMar 27, 2019NetDuma Partner
Download this firmware: https://kb.netgear.com/000060127/XR500-Firmware-Version-2-3-2-32
Then follow the instructions in that page on how to install.
