moreproblems's avatar
moreproblems
Follower
Sep 05, 2018
xr500
got a xr500 router  connected pppoe with centurylink modem.  even got the extender for it.
Since then, my surface pro behaves sooo slowww.  xboxone s won't hold a connection to ea servers.  I pad is slow.  I thought netgear was the way to go?
  • FURRYe38's avatar
    What FW is currently loaded?
    What is the distance between the XR and the extender? 30 feet is recommended in between them to begin with depending upon building materials.
    What Mfr and model extender did you install?
    Does the xbox and surface work well with out the extender installed?
    Disable MIMO and HT160 on the XR router...
    I had my XR450 installed and a EX7700 40 feet at the other end of the house. Great coverage and performance. However my xbox is always wire connected.
