Wurmkiller
Oct 01, 2019Follower
Xr500
I’m recently set up my XR500 to my gigabit internet and in the instructions it didn’t appear to say that I required a modem. I don’t have cable, just internet and my old router plugged directly into the main data line coming into my house. When setting up my router I see that I have very low download and upload speeds. I have seen that everyone has said this router requires a modem, would getting a modem help with my speeds?
1 Reply
Is there a ONT or a outside service box that feeds to a wall out let using a RJ45 port?
No the XR doen't require a Modem if there is a LAN wall port providing services to a RJ45 port on the wall.
The service should go from there wall out let port directly to the Internet Yellow port on the back of the XR router.
Try a factory reset on the XR router and walk thru the set wizard. Does the wizard detect your ISP speeds or something lower?
You can manually input the speeds under QoS, set them to 1000 for both UP and DOWN.
