JonSnowKnowsNad's avatar
JonSnowKnowsNad
Apprentice
Dec 20, 2019
xr500
On the latest firmware. Geo-filter doesn't show ping when playing modern warfare 2019
  • When you're playing do you see any icons or servers appearing on the map? Do you have Auto Ping enabled? If so does the Ping Panel appear but just not show the ping? If you don't have Auto Ping enabled you will have to click the server icon in order to ping the server. Auto Ping can be found in the Geo-Filter Map options.
    • JonSnowKnowsNad's avatar
      JonSnowKnowsNad
      Apprentice
      Yes I see the servers and I have auto ping enabled. I also see info like send rate, tick rate but no ping
      • Netduma-Fraser's avatar
        Netduma-Fraser
        NetDuma Partner
        That's very odd, it can take some time to appear depending on the server, does it ever appear? If you disable Auto Ping and then manually ping the server does the ping appear?
