fabiobotelho's avatar
fabiobotelho
Follower
Sep 30, 2020
XR500
Hi all
I just bought an XR1000 and I have an XR500, so I was thinking to place the XR500 on my second floor without need cable connection to replicate the XR1000 signal. It's possible? Can I make my XR500 to work as a mesh?
  • plemans's avatar
    The XR500 doesn't have extender/repeater mode.
    You could hardwire it in via ethernet connection, powerline connection, or moca adapter (ethernet over coax) and use it in access point mode.
    • Netduma-Fraser's avatar
      Netduma-Fraser
      NetDuma Partner
      Would just reiterate the above, using it in AP mode will be your best option.
