Charlietooth
Dec 31, 2022Tutor
XR500
Hi guys ! Happy new year to all of you , just purchased this amazing router and im having a problem with my Samsung smart TV , tv can't connect to ethernet via wifi or via cable . Can someone tell me the solution please . Thanks in advance .
- Netduma-FraserNetDuma PartnerHappy New Year! What does it say when it can't connect exactly? For WiFi you may need to disable Smart Connect and try to connect it manually to 2.4 or 5GHz.
Right i managed to connect to wifi , everything works on tv apart from Siptv app , im using that app to watch iptv channels and it wont open any channels . Dont know why
It's somehow blocking iptv from playing , cause im getting stream cant play error.
